Viewing and editing survey drafts (that were created on mobile) on the desktop
1500
01-19-2022 01:10 PM
Status: Open
RobbieZhuang
Is there a way to view and edit drafts of surveys we started on mobile on the desktop?
2 Comments
DougBrowning
If it is a draft that is much harder since it is not in the service at all and only on the device.  So it will be some manually copy of the data to get it off the device.
One way would be to use recovery from the device.
See here
https://support.esri.com/en/technical-article/000024617
MichelleWilliamsERM
Hi Robbie,
Why is it in draft?
If this is because they aren't ready to submit the survey, why not include a field with select_one Draft and Submit? So they can send it to the cloud.
And then, you can tell Survey123 to send drafts back to the inbox. AND THEN you can edit it in the mobile or desktop app. JUST REMEMBER always refresh, so you have the current data in your inbox.
