View and Edit Attachments while in edit mode in a web browser
2359
04-01-2021 04:23 PM
Status: Open
Labels (2)
RyanBohan
I would like to be able to view and or edit Attachments while in edit mode in a web browser.  I have a feature layer with attachments, that I would like to be able to edit them using mode=edit&globalId.  The edit mode functionality works great for updating everything else.
  If it's not possible to edit attachments at this time, it would be nice to have a read only option for displaying the attachment.
Thank you,
Ryan
4 Comments
StrathconaBTS
Has any progress been made on editing surveys with attachments?
The lack of this feature has a large impact on our use of Survey123.
DanielWickens
@RyanBohan -  I have a Survey that was built in Connect embedded in a dashboard for updating existing records, and you can use a file question type in the XLS form in Survey123 Connect to be able to add/delete/update attachments. This works for both attachments on the main feature layer as well as related tables.
NourSalamJMT
@DanielWickens which survey123 connect version were you using and was this in ArcGIS Online or in ArcGIS Enterprise? I am trying to accomplish the same thing you have.
DanielWickens
@NourSalamJMT - This survey was built using Survey123 Connect version 3.20, and is part of the GIS Request Management Solution, which is supported on ArcGIS Online and ArcGIS Enterprise 11.3 and later.
If you want to explore further, I suggest deploying the solution and opening the GIS Activity survey form in Survey123 connect to see how the XLS form is configured. Also, look at the GIS Activities dashboard configuration to see how the survey was embedded in the dashboard and configured to be used in edit mode.
Feel free to reach out if you have any questions.
