Use Webmap Bookmarks in Survey123
1793
02-23-2022 12:53 AM
Status: Open
Labels (3)
DavidGifford
Make web map bookmarks available in Survey123. Instead of unnecessarily creating multiple basemaps a simple web map bookmark would suffice and would be a great time saver.
Additionally, if the bookmark could be applied from a Survey123 form question this would help the survey user too.
Tags (1)
3 Comments
MichelleWilliamsERM
Yes, please!
AND they also need to download for offline use.
MichaelHeilen
I wholeheartedly agree. Many users of Survey 123 forms ask for this. It would be very helpful to allow bookmarks for maps in Survey123.
It would also be very useful for location questions (geoshape, geopoint, geotrace) within repeats to zoom to the extent of a previously drawn shape. For example, if a survey had the user enter a project location using a geoshape question, and then the survey had the user draw within a repeat the locations of things within the project area (such as the locations of structures that will be built within the project area or the locations of storage tanks that will be placed within the project area), it would be very useful for the map to zoom to the project area that was entered in the previous geoshape question. That way, if a user has to draw multiple locations within a repeat, they don't have to keep relocating themselves in the map.
PeterKnoop
Another use case for surfacing a web map's bookmarks in Survey123 is for when you need to collect, but are not actually at the location you want to select, and need to record the location manually.
When you go to collect a new survey, a geopoint question opens the map at your current GPS location. You can pan/zoom to your study area, however, this is time-consuming to do when you are on the other side of the world. It would be helpful to be able to select a bookmark to jump to your study area more quickly and easily.
