Survey123 Web Designer should have all Functionalities of Survey123 Connect Progressively Included and Integrated
802
04-19-2023 04:11 PM
Status: Open
rsun_TQB
Survey123 Web Designer should be made as powerful as Survey123 Connect. Web Designer should remain functioning even when a survey was created using Connect. Good features should be migrated from Connect to Web Designer progressively. I really think this will make Survey123 more competitive compared with other form applications out there other than just its functionalities to be used with AGOL and Enterprise or other geographic features.
Excel will always be with us for a long time, but if we can stay away from requiring three products (Web, Connect, and Excel) to make one survey, won't that be fantastic?
Reno
4 Comments
BrandonA_CDPH
I would like to add a slight variation as s use case. I would like the ability to edit/update a form in the Web Designer, even when published with Connect, even if limited to the capabilities in the Web Designer. For example, if I have a form that is published through Connect, I would like the capability to add fields without advanced features or move field orders using the Web Designer. I could return to Connect for the more advanced features, but would be able to make basic edits in the Web Designer.
rsun_TQB
Hi @BrandonA_CDPH,
Thank you for your valuable comment. I believe this will make S123's user experience way better, and increase adoption of using S123 as well for more organization to reduce technical barriers.
RenatoSalvaleon3
Edit button to open the submitted survey back in the web browser, instead of doing this edit URL:
https://doc.arcgis.com/en/survey123/browser/get-answers/editexistingdata.htm#ESRI_SECTION1_C4ECC19E6...
Tiff
@BrandonA_CDPH excellent suggestion! I have thought the same thing on multiple occasions and I absolutely agree that this would be helpful functionality to have.
