Survey123 Data Loss Problem on Decimal Fields
1422
07-18-2019 11:09 AM
Status: Open
UhullGoGoGoGo
Context
Different countries use different symbols as a decimal or thousands separator.
Some use a period, others a comma. Take a look:
Decimal separator - Wikipedia
Depending on how Survey123 field app interprets these symbols, this can lead to data loss.
The problem
Supposing the expected decimal separator is a comma, Survey123 behaviour is the following:
Value typed in a surveyValue actually stored in the Geodatabase
11
1.111
1.12112
1.1231123
1,11,1
1,121,12
1,1231,123
As you can see, if the user thinks the correct decimal separator is a period or simply forgets what is the correct one, we'll end up having wrong values in the geodatabase. This is problematic.
Proposed Solution
Survey123 web interface already has the solution: it doesn't allow you to type the thousands separator.
So... bring it to the app too!
