Hi S123 Team,
Please consider the option to share a draft of a survey before publishing!
Many times with the current workflow we create a survey and need to pass it off to a different department for review. In order to share the survey the survey schema must be published and solidified. Sometimes this review results in change and depending on the level of change, this can affect the existing schema. S123 is pretty good about tacking on additional fields when there's a schema change but the result is numerous archive fields that are unusable. If there were an option to share a draft of the survey before publishing creators could avoid these additional fields all together.
