Support html in constraint_message
771
12-09-2025 08:38 AM
Status: Open
MikhaylaB
I'm hoping the use of html in constraint messages in survey123 connect will be supported at some point. It would be nice to format and provide nice clickable links in that field when using booleans and constraints. As an example if user selects option A, provide a constraint message to direct user to proper link, if option B, open the rest of the survey.
3 Comments
Neal_t_k
Why not just configure a relevant note field with the URL. You can keep the constraint, just put your constraint msg with the URL in a separate note field.
AlfredBaldenweck
You tagged this as Connect, but HTML is possible for constraint messages in Connect.
Should this be relabeled as "Designer"?
Neal_t_k
@AlfredBaldenweck html works in constraints in Connect, however if you configure a link in the constraint message it is not clickable, like it is in a note.  Using a note as your constraint message should work in both Connect and the Web designer.
