Select Features in Survey123 Map (Geopoint Question)
2980
08-30-2022 06:28 AM
Status: Open
RobertAnderson3
MVP Regular Contributor
Functionality I would love to see added to Survey123, especially with all the new updates to pulldata(@layer) and such is the ability to select a feature on the map and have it pass attributes to other questions in the form (e.g. an Asset ID).
I know there is the multi-app method with this using custom URLs in Field Maps or integration in Workforce, however having to use multiple apps is cumbersome for field users. I have also come across issues with coordinate conversions in this URL method that neither I or Esri Support have been able to sort out.
This is similar to a suggestion here: https://community.esri.com/t5/arcgis-survey123-ideas/enable-selection-and-pop-ups-in-survey-maps/idi...
But I was recommended to create an idea as well so I want to make sure it gets the support and traction to get bumped up in the product plan since Ismael has said it's in the backlog.
3 Comments
MarkWILSON_LLS
#pulldata #pulldataoffline
hey @RobertAnderson3 .
I think I'm after the same functionality as you. Pls let me know if you've found this answer elsewhere on the site.
I'm ideally after an offline version of pulldata(@layer) and instead of pulling direct from a public feature service, I could side load that feature service into the linked webmap in Svy123 and pulldata would access the data from there.
I have used the Collector to Svy123 URL connection before offline and it's fine but this current workflow I need to select multiple polygons (reserves) and link them to 1 survey (pesticide record or asset inspection etc)
I have this working in an online capacity by loading all the reserves within a relate. The relate contains the geopoint which then pulls the reserve name and a host of other fields including the reserve GlobalID so I can link them back as a view table to load to dashboards etc.
many thanks
mw
MarkWILSON_LLS
similar thread to https://community.esri.com/t5/arcgis-survey123-questions/any-similar-function-to-pulldata-to-work-wi...
keen to hear any answers or if this is in the pipline @IsmaelChivite
Many thanks. mw
ahargreaves_FW
Plus 1!
This is badly needed. As the OP states we also have workflows that need to occur in S123 and use maps embedded into surveys. Jumping to/from FieldMaps is not do-able for this workflow. We currently employ the
