Replace submit checkmark with the word "Submit"
1498
12-27-2022 05:52 PM
Status: Open
JohnLeon
Using Connect, can the check mark symbol used for submitting be replaced to read as “Submit”?
1 Comment
ThomasM
Yes. You can use a "Note" field type with a specific question name to change elements of the UI, including the form title/description, submit button text, survey footer, and thank you screen. Here's the link to the article on exactly how to do it and a screenshot of the specific question names: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformnotes.htm#ESRI_SECTION1_31E80EF0A3...
EDIT: This only works for the Web App. It cannot be changed in the Field App (because it doesn't use text for the submit button).
