I recently had a workflow requirement where I was creating a survey that would meet the following needs:
The application is a tree giveaway where there are multiple landowners requesting different tree species and there are only a certain number of each tree species available; the survey needed to be able to display whether or not a tree species was available to order based off all previous survey submissions - so, in real time - and allow the landowner to be able to order based off availability.
I know that you can making limitations within the survey itself (Ex. Only can order 1 tree per survey), but I could not come up with a solution within Survey123 Connect that would allow for real-time limitations on type of tree species available to order based off previous survey submissions.
