(IMPLEMENTED) Generate Feature Report directly by URL Parameters
12667
37
07-17-2021 02:00 PM
Status: Implemented
Hussam_AlJabri
I designed two smart forms for my company and leverage the data to be in the dashboards where the end-users could generate the feature reports by configuring the popup in the webmap and adding the URL to generate feature reports.
What I did exactly was using the URL parameters of the report as below:
https://survey123.arcgis.com/surveys/XXXXXX/data?report=templateItemId:XXXXXX;format:pdf;objectIds:all;mergeFiles:nextPage&extent=58.3926,23.5739,58.3966,23.5744&filter=(0.dss_gis_objectid%20is%${dss_gis_objectid})
There might be the possibility to enhance the generating report by URL and adding all the fields in the report panel as a URL parameters of the "report="
report=
Select a template: templateItemId:XXXXXX;
Format: format:pdf;
Choose records to include:
objectIds:all;
Output settings:
mergeFiles:nextPage;
My sugession to add:
Report name
Save to my ArcGIS account (check or un check)
Generate button
So the users will generate the reports by clicking only on the link through the ArcGIS Dashboards and ArcGIS Field Maps in the popup or any platform!
See the video for more clarification.
Tags (1)
37 Comments
MajidAlabrawi1
hi @ZhifangWang , @ChristopherCounsell
actually , i have work on the generating report tool embedded in dashboard the token will be updated directly once you open the dashboard
LouisDECOMBE
hi @MajidAlabrawi1
i'm interested about your solution in dashboard if you can explain us how you did.
Thank you
MajidAlabrawi1
hi  @LouisDECOMBE ,
sure, soon I will share the full solution in GitHub and how to deploy it in enterprise and AGO
i will let you know when its live
ZhifangWang
Hi all,
In the June 2024 Update, we will introduce a new report page for generating reports. It looks similar to and has the same capabilities as the report panel on the Data tab, but it excludes other UI elements, so it can be embedded in other pages or apps.
Please feel free to try it out by following the details in this EAC document: New web page for Survey123 report capability.
Any feedback, please feel free to post in the Survey123 Beta Website Feedback forum. Thank you.
ZhifangWang
In the June 2024 Update, Survey123 introduced a new report page for generating reports. It looks similar to and has the same capabilities as the report panel on the Data tab, but it excludes other UI elements, so it can be embedded in other pages or apps.
Blevins_Mark
OussamaMerhi
Hi.
I am new to this topic. I didn't know from where to start. can you please provide me step by step to integrate it in dashboard.
Thanks in advance.
