Dear All,
I think it will be super fantastic to have a ability to set up rules to prevent final submission when end users click on the "Submit" button.
If a question of an disclaimer is "No", then submission will not be allowed.
Reno
I have a workaround for this, but it is not very intuitive. I mark a field as required, then use a calculated expression to make it equal null until certain conditions have been met. Typically I use the “Completed By” field and populate the username, but it could be any field.
Usually the field is hidden, but you could re-label it as “Please complete the form” and then hide it once conditions have been met to make it a little more clear to the user.
Form submission criteria would definitely be an improvement!
This can already be achieved.
Two options:
