Currently in Survey123, Select One or Select Multiple questions that are picklists/dropdowns, require the user to scroll through the potential values to find the right one. For questions that have long lists, this is cumbersome because the user must scroll through the list to find the proper value. It would be great if the user could start to type the answer and have the picklist filter down to the potential values that meet what the user types.
As an example, there might be a question where the user must pick the City from a picklist. There may be 25+ cities in this list and the user has to scroll down through the list to find the appropriate one. If the user was able to type part of the city's name and have the list dynamically change, it would prevent the user from having to scroll through the list.
Below is a Survey question in which the user must select the appropriate cit. The user must scroll down through the list to find the correct city from the picklist. If the user was able to start typing in the City name, the list potentially could narrow down to the answers that meet what the user typed.
