Would like the have the ability to filter and edit Survey123 Select Multiple Question Fields. For filtering it would be nice to be able to filter them in Dashboard as well as web-maps using a single select or multi-select drop-down filter with all of the possible question answers being available. For editing It would be nice if you could edit the same question in the web app "smart-editor widget" using a check box type configuration like it is in Survey123.
Josh
Hi Josh, take a look at a similar idea I posted to deal with the Dashboard side of this problem:
