Field App: Switch Users/Active Portal
100
a week ago
Status: Open
AlfredBaldenweck
MVP Frequent Contributor
I'm certain I've seen this before but can't seem to track it down. Maybe on the Field Maps board?
In any case:
We have users drawing surveys from anywhere from 1 to 5 portals. S123 is great because you can see all the downloaded surveys regardless of which portal you're signed into, but what's been a pain point this summer is that they go to submit a survey to the wrong portal and get hit with an error message and confusion.
I would like to be able to just be logged in to multiple portals at a time, similar to the way portals are managed in ArcGIS Pro.
This would allow users to just submit to any of the logged-in portals, without having to log out, log in, repeat. In the case of several users, they can't remember which portal does what, so there's a lot of trial and error to figure it out. Logging in to more than two portals is pretty painful and time consuming, and my hope is that this would smooth it out a bit.
2 Comments
Neal_t_k
Not optimal but until its addressed you could just put a portal id in the name.
SaadShahzad
Agreed, we've got contractors that are using Survey123 for their own company, and they're also logging into our portals, so it's a bit clunky when they have to switch between multiple portals.
