Editing Existing existing survey data attached photo is not supported
3111
03-08-2021 02:46 PM
Status: Implemented
TimvanderVelden
When prepare a survey for existing survey data it isn't supported to attached photos Attached photo's is only possible with collecting new surveys. In the documentation is a alinea that discribe:
"if your survey's workflow requires editing of submitted surveys, be aware that editing of attached photos is not supported"
Prepare for editing existing survey data—ArcGIS Survey123 | Documentation
I Hope this will be soon integrated, because this is really critical when you work with existing survey data
5 Comments
IsmaelChivite
Thanks @TimvanderVelden   Support for attachments in the Inbox is currently scheduled to be made available before end of 2021.
JamesTedrick
This has been implemented in Survey123 3.13
JamesTedrick
Hi @TimvanderVelden ,
Just to check, is the need you are expressing to only add new photos when editing a record or to edit (delete/replace/alter) photos that have been taken previously?
JamesTedrick
TimvanderVelden
Good news, although the project is already finished. It's solved with a workaround with 2 surveys (new and existing) that are combined on a unique ID afterwards.
If I'm correct adding photo's is possible possible with existing data and also deleting, replacing en alter existing photo's?
