Survey creators should be able to configure 'time' and 'dateTime' questions so end users can enter this information following a specified time format.
For example, I would like to configure a date time question so the time is entered always following military (24-hour time) format. Currently, the datetime and time questions get the time format from the locale of the device. This is not ideal. I want to control the time format for data entry.
As an idea of what the XLSForm syntax could look like: New syntax for the body::esri:style or appearance columns.
Hi @Katie_Clark Thanks for your idea. I see a couple of different asks in your idea. Please let me know if I understand your request correctly:
For #1 above, what do you think about using the body::esri:style column to define the format that the Date/Time widget should use? Would that make the trick for you? It is not currently implemented, but this could potentially be a solution for consideration.
For #2: Regardless of the format used to capture the date/time, you can control the format used to outptut a Date/Time value in a PDF report. For example:
If you want to add AM/PM, use A (or a if you want it as am/pm).
Hi @IsmaelChivite ! Thank you for your response!
For #1, yes I think that would work well as a solution. Either that, or using the "appearance" column, whichever makes more sense.
For #2....I posted this idea quite a while ago and I have learned so much since then, including being able to better format data outputs in a custom report template. But thank you so much for clarifying about the "A". It might be helpful to include that particular syntax in the quick reference guide (as you show in your screenshot) as well?
Thanks!
@Katie_Clark Thanks for the quick response. I adjusted the original text to make it more direct. Lets wait and see if this idea gets traction. Thanks again.
The proposed request #1, about using the body::esri:style column to determine the format of the time question would help me out a lot. Often times, I have staff who need to collect multiple time questions either in the same form, or across multiple forms and being able to control that on a question-by-question basis would help us further control the user experience!
