❌ Dependency cycles amongst the xpath expressions in relevant/calculate\n\nResult: Invalid
✔️Dependency cycles in ${field_name}
Can this error message include the offending field name?
Can it also be made so that the error messages can be interacted with, (select all, copy)
@ACharvinThis is a really good idea. I would suggest making your own Idea thread. That will give Esri a much better chance of seeing it!
