It would be helpful to be able to have Repeat questions in the Survey123 web designer like there is in Connect.
Currently you can design a survey with repeats in Connect, which displays like the web designer version when deployed in apps like Experience Builder or Hub. However, this puts the plus sign to add a repeat at the start of the repeat, rather than the end, which is a counterintuitive UI, especially when the number of repeat questions means the user has to scroll back to the top. This also does nothing for surveys created in the web designer.
