It would be amazing if when designing a new survey in Survey123Connect, there was the option to give a meaningful name to my hosted feature service, rather than have it named a string of letters and numbers by default (e.g. 0c99465e76ea4105bc22e658dc4517b8). This is becoming increasingly important in my work, where I share ArcGIS Enterprise space with all state employees in my state, and organization within "/server/rest/services/Hosted" is key, especially for admins!
You can always create the service first, then use Survey123 Connect to create a survey that references it.
@jcarlson thank you so much for the response. I have actually already looked into that, and it's much easier said than done, especially when you are publishing a service with relationships between two feature layers. In terms of user-friendliness of Survey123 operations, it would be so much easier if Survey123Connect provided the option to name my service.
