Allow border and background colors when using Grids and Repeats
323
10-21-2019 07:44 AM
Status: Open
DougBrowning
MVP Esteemed Contributor
The help says you cannot style a repeat that is inside of a grid. But it seems like I can also not style a repeat that has a gird in it.
Idea is to allow color coding even with a grid.  Other option is to allow us to set the text or color of the repeat bar at the bottom.
My issue is I have one big master repeat around the form. Then I also use pages. And then some more repeats. This causes cases where I have 2 repeat boxes stacked - which is confusing. Is there any way to rename or style the actual 1 of 11 area yet?
The Transect repeat (A) at the top goes with the 1 of 11 at the bottom. The Station repeat goes with the 1 of 10.
Thanks
Tags (1)
