What's new in ArcGIS Survey123 September 2023
1340
09-20-2023 09:37 AM
IsmaelChivite
Esri Notable Contributor
4 1 1,340
The September 2023 release includes a few important fixes to the Survey123 website and web app.
  • INC-000193 - "Error: Initializing form... TypeError: Cannot read properties of null (reading 'attr')" When Opening Survey123 Webform.
  • BUG-000155109 An ArcGIS Survey123 signature question is cleared when changing the mobile device orientation (e.g. from vertical to horizontal). This allows empty signature submissions to required questions.
  • BUG-000137890 When submitting a form from the ArcGIS Survey123 web app, if the selected date in a Date question is outside the daylight saving days (Mar 12 – Nov 5), the time is captured as 11:00 AM instead of 12:00 PM
  • BUG-000157091 -Required questions in repeat_count no longer display error message
  • BUG-000158582 In ArcGIS Online and ArcGIS Enterprise 11, deleting a survey form from the ArcGIS Survey123 web app removes the web map from user content
  • BUG-000155623 When removing the default survey description from a survey in the ArcGIS Survey123 web designer, a note appears suggesting hiding the survey description from the Appearance tab, although this option is located under the Add tab
  • BUG-000161021 The 403 error is returned on the request body format of 'x-www-form-urlencoded' with any tag in the HTML content in the request parameters of addItem
  • CAPTCHA control in the Survey123 web designer is no longer Beta.
Our next release is planned for November. We will make an announcement shortly to let you know what is coming in this release and the new features you will be able to test through the Survey123 Early Adopter Community.
1 Comment
