On December 6, 2022 we will release a new update to ArcGIS Survey123. A Beta version of this update is available for testing. Here are the highlights:
• BUG-000153696 Survey123 Connect fails to publish a survey with error "Fields not found in the feature service: 0" when using an existing feature service if a question label doesn't match the field alias in the feature service.
• BUG-000117385 Coded integer values in a feature service created by Survey123 Connect for ArcGIS are not appearing in the web app attribute table.
• DE-000005891 ENH-000127565 Enhance Survey123 Connect so that the “repeat _count” field is not added to the schema and therefore not required in the feature service.
• BUG-000151353 Select_one questions in a webhook output are a numeric type only when submitted from the ArcGIS Survey123 field app.
• BUG-000151226 Using dynamic labels in groups with the table-list appearance fails to display the select-one question dynamic label in ArcGIS Survey123.
• ENH-000135042 Allow for Survey123 Mobile App to send users back to the log in page after password is changed when using Portal for ArcGIS accounts configured with IWA.
• Fixed a bug in which the incorrect week number was displayed during day light saving time when using the week-number appearance.
• Improved app navigation in right to left language display.
You can download the Beta version of Survey123 Connect and the field app from the Early Adopter website. You will also find forums to post your feedback. All the fixes above will be in our December 6 update.
Multilingual survey authoring from the Survey123 web designer is a very strong candidate for the December 6 release. We are looking forward to your feedback for further functional and UX improvements.
We have organized a live session to test these web designer features on November 29. Find more details here. If you cannot join us, learn how to access the Survey123 Beta website from the Survey123 Early Adopter community.
The Survey123 Microsoft Power Automate connector includes a Create report action. This allows you to automate report generation using Microsoft Power Automate.
If you want to test this new action, join us for our November 29 sneak peek session. We also plan to make this available in early December through the Survey123 Early Adopter community.
