Calculating distances between multiple Geo-Points in a survey with the Haversine Formula
8326
12
01-10-2018 04:44 AM
DeonLengton
This blog post provides a solution for:
    Capturing multiple locations per survey
    Calculating straight-line distances between a base location point in the survey and other repeating locations         captured
Consider the scenario where your survey must assist in the administration of new liquor licence applications and the law stipulates: New liquor premises must be located at least five hundred meters (500m) away from schools, places of worship, recreation facilities, rehabilitation or retreat centers, residential areas and public institutions.
For this requirement Survey123 can be a valuable tool and in this blog post I will show you how you can enable this functionality in a Survey123 form:
Step 1: Create a new survey with Survey123 Connect
Step 2: Create a geopoint field in the main survey which will be used to capture the location of the new licence premises (the base point or new_licence_location field in the survey below)
Step 3: Create a repeat section to capture the occurrences of nearby schools, places of worship etc. Each with a premise type and a geopoint (the nearby_location field in the survey below)
Your survey design should look similar to this:
Step 4: Now, split both the coordinates sets into their x,y pairs and convert them to radians:
Do the same for the nearby_location geopoint field:
Step 5: Use the X, Y (lat,long) pairs to perform the distance calculation (in meters) with the Haversine formula:
acos(sin(${gps_lat_end})*sin(${gps_lat}) +
cos(${gps_lat_end})*cos(${gps_lat})*cos(${gps_long}-${gps_long_end}) ) * 6371000
After making some cosmetic enhancements (and adding the 500m stipulation) your survey should look like this:
The user can add multiple locations (Nearby Premises) at will in the repeat section and each will have it's own distance calculation to the base point (New Licence Location).
The Survey123 Excel Design file is attached to this blog.
Feel free to use and adapt as you require!
12 Comments
DornMoore
Thanks for posting this Deon!
Do you have any thoughts on using the Haversine calculation to determine the coordinate of a feature depending on the azimuth and distance from the location of the device collecting the information?
For example, locating the location of an animal as part of a wildlife survey. The field user is provides a geopoint with the location of the observation, an azimuth and a distance (meters) and Survey123 stores the derived geopoint? I cannot imagine why this wouldn't work but I'm not sure of the formula to use.
If you think this will work and can provide some guidance, we will put it to work right away. Apologies if this has already been posted somewhere else.
DeonLengton
Hi Dorn
Thank you for reading the blog. What you need sounds do-able. I will have a look as soon as I get a chance and see if I can that working. This website seems to discuss exactly that: Calculate distance and bearing between two Latitude/Longitude points using haversine formula in Java...
Lower down in the article they discuss destination point given distance and bearing from start point...
DornMoore
Thanks Deon.
I think the scripts you linked to will help. The real challenge will be 'adjusting' the resulting geopoint that is stored in the survey and not the observer point.
DeonLengton
Hi Dorn
Only having one geopoint per "table" will cause a problem though. Do you foresee having this in a related table? So the user is capturing his "base" point and then all the observations from there are in the related table?
by Anonymous User
Not applicable
Hi dlengtonesri-southafrica-esridist‌,
Thanks so much for posting this. I have a question related to this blog. And any help on it is greatly appreciated
I have lats and longs for 8 different facilities in our city. Dependant on where the survey is undertaken, is it possible to pre-poulate a select_one question to the nearest facility?
i.e. Which facility are you rating? (Pre-populate answer dependant on the nearest facility to user’s location)
Gee
DeonLengton
Hi Gee
Will there always only be 8 facilities? If so, then you can calculate the distance of the user location to each one of the facilities and default the select_one to the correct one... But this will only work if you have a static number of facilities though. I have done something "similar" and published the Survey123 source files to AGOL:
AGOL Survey123 Solution Resource Item Zipfile
In my example you will see the following:
   1) Let the user choose one of the facilities and see it on the map
   2) Let the user retrieve the device's location from which the survey will then calculate the closest facility
   3) Once a closest facility has been calculated then that is the only option to choose from in the select_one
I know you want to allow your user to still choose one of the other facilities - see if you can get that to work, I havent attempted that yet!
by Anonymous User
Not applicable
Thanks Deon, this is extremely helpful
Yes, the number of locations will always be a static number. And this workaround is PERFECT.
THANKS,
Gee
DougBrowning
MVP Esteemed Contributor
Been using this all the time. Thanks a lot!
PhilRees
This is amazing, thank you! I have a question - when using this to measure the distance from geopoints in one repeat to a geopoint in another repeat, does it measure to the last geopoint in that repeat?
My example is:
Repeat 1: points around the edge of a building (lets say 4 if its a rectangle).
Repeat 2: points located position of electricity poles (lets say there's two in the repeat, at opposite sides of the building).
I want to calculate the distance from each pole to the nearest point of the building. Ideally i'd measure from the repeating points (poles) to one geoshape (building) but i don't think this is possible, so trying a workaround to calculated from point to point.
Appreciate its a bit of a complex one, any help would be really appreciated!
ArayaAraya1
New Explorer
Thank you for sharing Deon!
I am trying to do something similar but asking people where they were born, where they grew up, where they attended college, and finally where they are now. I want to calculate the distance from where they were born to all the other locations I ask in the survey. I would appreciate your feedback.
anonymous55
This is great Thanks
ZachBodenner
MVP Regular Contributor
Hi @DeonLengton , this looks like a really useful tool! I know this thread is a bit old (maybe someone else could help too), but is there a way to hard-code the location that the distance calculation is comparing against? An example: say I have a user that places a point in the first geocode question, and I want to know how far away they are from a specific point. I'm guessing then I wouldn't need the second geopoint, but I would have to swap out the ${gps_lat/long_end} value in the formula with something static?
For my use case at the moment, I don't actually even care about units or how far away the placed point is, I just want to be able to compare who is closest amongst multiple submissions.
