ArcGIS Survey123 Deprecation Notes - May 2021
9184
15
05-07-2021 02:41 PM
IsmaelChivite
Esri Notable Contributor
4 15 9,184
With each ArcGIS Survey123 release, we assess the platforms we support and adjust these based on customer requirements and technology improvements. The purpose of this article is to provide as much advance notice as possible regarding these changes.
The operating systems and web browsers supported by the current version of Survey123 are detailed in the System requirements help topic.
We plan to release ArcGIS Survey123 version 3.13 in August September 16 2021. This update will be built with ArcGIS AppStudio 5.1, which includes changes to the minimum requirements for various operating systems.
iOS 12 (Survey123 field app)
Starting with Survey123 3.13, the minimum supported version of iOS will be iOS 13. The following Apple devices will not be able to run ArcGIS Survey123 3.13 or later: iPhone 5s/6/6 Plus, iPad Mini 2/3, and iPad Air (2013).
Note: Users on iOS 12 can continue using ArcGIS Survey123 version 3.12 or earlier if already installed on their devices.
Android 5.x (Survey123 field app)
As anticipated in our ArcGIS Survey123 Deprecation Notes (November 2020), support for Android 5.x (Lollipop) is coming to an end. Starting with Survey123 3.13, the minimum supported version of Android will be Android 6.0 (Marshmallow). Survey123 3.13 will be the last version with support for Android x86.
Note: Users on Android 5.x can continue using ArcGIS Survey123 version 3.12 or earlier if already installed on their devices.
Windows 8.1 (Survey123 field app and Survey123 Connect)
Support for Windows 8.1, Windows 8.1 Pro, and Windows 8.1 Enterprise (32 bit and 64 bit) is planned to be dropped before the end of 2021. At that point, the minimum supported versions of Windows will be:
  • Windows 10 Pro (32 bit and 64 bit) minimum version 1809
  • Windows 10 Enterprise (32 bit and 64 bit) minimum version 1809
  • Windows Server 2016 (64 bit)
  • Windows Server 2019 (64 bit)
Windows 32 bit (Survey123 field app and Survey123 Connect)
As of March 2020, Microsoft no longer offers a 32 bit version of Windows to OEMs for new PCs. While the exact end-of-life date for Windows 32 bit operating systems is unclear, Esri plans to drop support for Windows 32 bit operating systems before the end of 2022. This will affect users of Survey123 Connect and the Survey123 field app.
Ubuntu and macOS  (Survey123 field app and Survey123 Connect)
ArcGIS Survey123 3.13 will be the last version with support for Ubuntu and macOS.
Survey123 field app availability in the Amazon store
3.13 will be the last version of Survey123 available in the Amazon Store. Users who cannot download apps from Google Play can install Survey123 from the .apk file included in the Survey123 resources page.
15 Comments
