Tour from Feature Class Media
433
02-18-2022 10:33 AM
Aurust
I'm just getting started with creating a Map Tour from a Feature Class. I'm wondering how to add media, specifically a picture to my point feature class? I'm looking for a different picture for each point.
OwenGeo
Esri Notable Contributor
Hi @Aurust -- Media for a map tour comes from the feature layer attachments.
Can I ask why you are using the feature layer option for your tour instead of creating the points in the story builder? The option to create a tour from a feature layer is mostly there so you can create a tour from an existing data sources created from other ArcGIS apps like Survey123, QuickCapture, or ArcGIS Field Maps. Creating a feature service manually is typically a lot more work than using the story builder, so we usually only recommend that option when you already have a feature service that you want to create a tour with.
Owen Evans
