The layer legends are not updating correctly when switching maps within my story map, using the side car. I think this is a bug.
6946
10
10-26-2020 12:58 PM
ShawnaLReid
I am creating a side car section within a larger story map.  I've created multiple maps in the context column in order to show specific layers in each map.  When switching back and forth between the maps, the legends do not update correctly. Maps are keeping the legend attributes and symbology from a previously viewed map.   How can I correct this?  Is this a bug that hasn't been fixed yet?
Tags (1)
KiraEvers1
I'm still noticing a similar issue. When I change the layer name in map viewer, the change is not reflected in the map legend used in my storymap. The only solution I've found so far is to delete the map from the storymap slide and then readd the map. Wondering if this bug is still on the list to be fixed?
Thanks!
