StoryMap not loading on iPhone
1573
02-17-2022 02:34 PM
FriendsMissRiv
I published our draft StoryMap to test it on mobile, and while it works on my iPhone and a friend's Android, it won't load for another iPhone I tested (iPhone 6S, version 11.2.6) — we simply see a blank white screen. That's for both Safari and Duck Duck Go browsers, with cleared browser caches.
Here's the StoryMap: https://storymaps.arcgis.com/stories/4d5321c2be8e4188ac175228763021f2
How widespread do you expect issues like to be for mobile viewers? Any ideas about what might be going wrong?
Second, what should we do to make our StoryMap more mobile compatible (in terms of image sizing, immersive element use, etc.)?
Thanks!
2 Solutions
BrendanNewell
hi @FriendsMissRiv,
I would upgrade to the latest version of iOS as iOS 11 was released back in 2018 and they now have iOS 15 available. once upgraded i would see if the issue persists
cheers
OwenGeo
Esri Notable Contributor
Hi @FriendsMissRiv I agree with @BrendanNewell, if you can update the device that would be a good first step, but some older devices may not support iOS 15 (I know I have an older iPad that can use anything more recent than iOS 12). The iPhone 6S, however, is compatible with iOS 15, so the device you are testing on should be upgradable. In general, most sources report that a very large percentage of iPhone owners are on either the latest major OS or the version before that, so this issue shouldn't be that widespread.
In terms of making your story more mobile friendly, ArcGIS StoryMaps does a lot of that for you. If you upload your images, the builder automatically optimizes them for the web and serves out specifically sized versions for mobile devices vs. desktop readers. Also be sure to add alternate images for any embeds so they look good on small screened devices (the builder prompts you to do this). Immersives are designed to work well on smaller screens. The experience will be a bit different, but the content layout is adjusted to try to give readers on small screens the best experience possible give the space constraints. You should always test out what your story will look like on phones and tablets using the multi-device preview mode that's available in the builder.
Owen Evans
BrendanNewell
hi @FriendsMissRiv,
cheers
OwenGeo
Owen Evans
