StoryMap Embed not retaining URL parameters
2220
16
11-16-2025 08:56 PM
GregoryHanton
Hi, has there been a change to the Embed option in StoryMaps at the October or November update releases?
I've previously embedded a number of Dashboards within a series of StoryMaps (each StoryMap focusses on a different geographic region) with each embedded Dashboard having URL parameters. This had worked really well, saving me from making multiple copies of a Dashboard (for each region) and instead using the URL parameters to filter the layers in my Dashboards.
However, when I try and embed a Dashboard with URL parameters now it is instead embedded into my StoryMap with the URL parameters removed. Even if I copy the URL of a previously embedded Dashboard via the settings in the StoryMap (which displays the URL parameters and filters as expected), and embed this again, the URL parameters are removed from the URL.
The format of my URL parameters are:
DashboardURL#region=Name%20Name
Thanks in advance for help / guidance to resolve this!
OwenGeo
Esri Notable Contributor
@GregoryHanton Thank you for providing additional information. We believe we have found the issue and are working on a fix. I expect that we should be able to address this in our next release in early December.
Owen Evans
OwenGeo
@GregoryHanton - I'm sorry that you are seeing issues with embedded dashboards. No recent changes in this behavior are expected. Are your StoryMap and dashboards shared with everyone? If you can you provide links we can try to look into this for you.
If they are not publicly available, please contact Esri Support and they can help you troubleshoot.
Owen Evans
GregoryHanton
Hey @OwenGeo , thanks for getting back to me.
Examples of where I've embedded dashboards with URL parameters applied and working can be seen here at the Hunter SRITP StoryMap; see the Cultural diversity section for an example.
I've setup a demo StoryMap with just the dashboard from the cultural diversity section embedded, copying the embed content reference / URL from the embed options in the Hunter SRITP StoryMap.
In this example the URL parameter isn't working and hasn't been retained on the embed content reference, however when viewing the JSON via ArcGIS Online Assistant for the demo StoryMap I can see the URL parameter on the embed URL - see attached image.
The URL parameter should filter the dashboard content to display values only for jurisdictions within the 'Hunter' region.
Thanks in advance again, sing out if you need more information.
OwenGeo
Owen Evans
OwenGeo
@GregoryHanton - This issue should be fixed. Please let me know if you are still having issues.
Owen Evans
SchaffnerBecky
@OwenGeo I have just run into a similar problem. I have an Experience Builder app (https://experience.arcgis.com/experience/a915cb5d987a474ca388d177c1a9b3c1/) with multiple pages for different organizations' data.  I would like to embed each page individually into a series of storymaps customized for each organization, but when I paste the long URL with the page name into the StoryMap, it truncates it to just the parent URL. So for example,  https://experience.arcgis.com/experience/a915cb5d987a474ca388d177c1a9b3c1/page/Hallowell-Conservatio... defaults to the home page, https://experience.arcgis.com/experience/a915cb5d987a474ca388d177c1a9b3c1
See the screenshots below. The first shows the full URL that I pasted into the web content box. The second shows the resulting truncated URL after completing the embed step.
OwenGeo
@SchaffnerBecky - This appears to be a different issue. We are looking into it and will see if we can address it in our next release in late January 2026.
Owen Evans
OwenGeo
@SchaffnerBecky - The issue you ran into with Experience Builder URLs was fixed in an update to ArcGIS StoryMaps last night. Please try again and let us know if you are still having an issue.
Owen Evans
SchaffnerBecky
Yes, it does appear to be working for us now. Thank you!
ColinBergmann_ct
@OwenGeo There is still a similar issue after the June 2026 update. When embedding experience builders with URL parameters into a sidecar, the slides do not refresh with the updated URL parameters between adjacent slides. For example, in my storymap, I have the same experience builder app embedded in back-to-back slides, each with different url parameters that change feature selection and layer visibility. However, embedded content does not reload between slides unless I put a blank slide or a slide with entirely different content between them.
