Story Map won't load in edit
1890
12-17-2020 05:50 AM
KennyCampbell
I'm working on a large story map project which I will have to split into two separate story maps due to its size. The issue is that I can't access my Story Map to reduce its size as I just get the out of memory error code on Chrome. Any suggestions appreciated. Thanks
OwenGeo
Esri Notable Contributor
Hi @KennyCampbell -- I'm sorry you are having a problem editing your story. The best way to get help with this is to contact Esri Support and they will be able to help you troubleshoot this specific issue.
Owen Evans
OwenGeo
Owen Evans
