Public shared story map asks to sign in
1141
03-19-2024 04:01 PM
NikhilLalwani
Hi ,
I have a story map available here :
https://storymaps.arcgis.com/stories/65566e6ac1c54aa18f16e5a1ce3e06e6
All content is marked public and I want to share it with non ArcGIS subscribers.
When I change the story maps permissions I get the following error :NikhilLalwani_0-1710888840955.png
On sharing the story map as viewers scroll down through it , at 2 of the visualizations they see
This only happens if users are not logged into their ArcGIS accounts . This is happening at a point where we uploaded few images.
The story map was working fine till ESRI did some updates to the story maps and that's when the errors started.
Thanks in advance for looking at this issue.
OwenGeo
Esri Notable Contributor
@NikhilLalwani -- I'm sorry you are experiencing this issue with your StoryMap. Were you changing the sharing from the Sharing settings option or were you republishing? I was going to suggest that you unpublish and republish the story to see if that addresses the issue.
If that doesn't work, we do have a fix coming for an issue with subscription/premium content layers in an update tomorrow evening. If the steps above don't work now, please try them again Thurs morning and let us know if you are still seeing the issue.
Owen Evans
NikhilLalwani
Yes, I tried to unpublish / republish and make it private/public multiple times but it still did not fix the issue. Hopefully the Thursday fix will work.
NikhilLalwani
Hi Owen,
This issue with permissions is still there. It did not get fixed on Thursday.
