Option to Use Map Viewer Classic vs New Map Viewer
1298
07-14-2021 10:27 AM
JosephHakam1
Is there a way to embed web maps into a Story Map using Map Viewer Classic rather than New Map Viewer? Some functionality from Map Viewer Classic is still not present in New Map Viewer - like viewing attachments from Map Image Layers.
Tags (1)
OwenGeo
Esri Notable Contributor
@JosephHakam1 -- When adding a map directly to the story via the Map option you'll always get the new map viewer pop-up experience.
If you need something else, you can create an app using one of the older configurable apps that still uses the classic pop-up experience and then add that to your story.
Owen Evans
OwenGeo
Owen Evans
JosephHakam1
Thank you, that's the workaround that I actually used - was just hoping there was a more straightforward option for the future.
@OwenGeo, Do you know when Map Image Layer attachments in New Map Viewer will be supported?
