iFrame will not Embed in Story Map
3923
04-15-2020 10:40 AM
ChristosPolitis
I'm trying to include an externally hosted Leaflet map into a story map using the embed iframe option.
https://www.p5hq.com/leaflet/index_deaths.html
It flashes into the frame for a few seconds, but then converts it into a card. There was an error message "website doesn't support inline embedding", but I'm using the same external source in an ArcGIS Hub page as an iframe successfully.
Tags (1)
AravindatStoryMaps
Hi Christos,
It looks like there is a TLS certificate error when embedding the link that you have provided. The certificate to the where the web server is hosted (p5hq.com) is not the same common name that the GoDaddy certificate is assigned to (.gridserver.com).
We require that all links to images, videos and external content be HTTPS compliant and the certificate is valid for our iframes to show up securely.
Hope that helps,
Aravind
AravindatStoryMaps
Hi Christos,
Hope that helps,
Aravind
ChristosPolitis
Thanks Aravind. Can you direct me on how to remedy this? I'm not familiar with how certificates work.
I've put in a support ticket to my server host (Media Temple, where gridserver resides).
Christos
AravindatStoryMaps
Hi Chris,
I'm not a subject matter expert on certificates, so i'm not able to comment on how to resolve the certificate error but here's a good knowledge article on how they work: What is SSL, TLS and HTTPS? | DigiCert & Symantec .
While you wait for the support ticket to resolve with your server host, you could alternatively choose to host the html app on other free alternatives (like Github pages, Netlify, etc.) which have a valid SSL certificate that will allow you to embed into our stories.
Let me know if this helps,
Aravind
