Change font in Storymap Tour when using a feature layer
276
09-26-2025 08:17 AM
Labels (2)
KG_427
It seems the font choices in a custom theme do not carry through when using a map tour that is created from a feature layer. Is there a workaround to this? It would be great to be able to use the same font throughout the story map and our website.
OwenGeo
Esri Notable Contributor
@KG_427 - Thanks for posting your question. Map tours created from feature services should use the same fonts as the rest of the story (which should be the fonts from your theme).
Is your story shared with everyone? If so, could you share a link to it so we can take a look? If not, could you share a screenshot of what you are seeing?
Owen Evans
OwenGeo
Owen Evans
KG_427
Hello, thanks for the response! I went in to take screenshots and, of course, it is working as expected now! Maybe it was a caching issue last week? I would refresh and there were no changes to the font.
Thanks again.
