Can't publish a story map to public
728
11
09-27-2025 03:10 PM
RussGreen
Hello!  I have an individual account but cannot publish my story map to public. Publishing private works fine.
When I try to publish to public, I get this message after it goes through "checking" and "publishing" and then returns to my story map: "There was a problem publishing your story." It's a little box that slides out from the upper right hand corner.
I've searched in this forum and others but haven't found the answer. I've made a duplicate of the story map and began systematically deleting elements (pictures, links to videos and outside webpages). But even when I get down to the barest bones story map I still can't publish to public.
I've checked my profile, etc and made sure one of those settings is also "public."  Maybe there are other settings I need to adjust.
This seems like a admin issue rather than and issues with story map content (I think!). I even made a story map with just a couple images and text fields, and that would not publish to public.
Any help is MUCH appreciated.
Tags (1)
RussGreen
Awesome- thanks for this. I created a free account.
Wondering now if there are limitations to transferring content between the trial account and the free account? When using the Online Assistant to copy my story map from a trial account to a new free account, I'm not able to drag and drop my storymap.
Any guidance on transferring, moving or copying my storymap to a new free account?
Thank you!
OwenGeo
Esri Notable Contributor
There is some documentation about this here. I don't believe there should be any issue with that. Make sure you initially sign in with the account you want to copy FROM first.
Common Workflows | ArcGIS Assistant User Guide
  • When copying a story between accounts (even accounts in the same organization), be sure to initiate the copy from the account that owns the story (or is an admin in the organization).
Owen Evans
