Info "Story Map not published" in Portal Item description
529
09-14-2022 04:30 AM
Status: Open
Labels (2)
SimonSchütte_ct
MVP Regular Contributor
When a Story Map is saved but not published, it can not be shared with a group. It is not obvious that the Story Map needs to be published first. The group sharing selection simply is not applied, which causes irritation.
- mark the Story Map as "Draft" or "Not Published" in the Item details
- show an error message when sharing is not possible caused by Story Map being in draft state
