Image gallery inside sidecar
1278
12-07-2021 02:53 AM
Status: Under Consideration
Labels (2)
JulieGrindborg
Hi, it would be great if it was possible to make an image gallery inside a sidecar, currently I have to edit the images manually together into one .png in for example adobe illustrator and then place it as a single image in a sidecar.
3 Comments
OwenGeo
@JulieGrindborg -- Would you like to add a gallery to a sidecar narrative panel or the main/media panel (or both)? Do you have any screenshots/links you can share of the manual collages you've created that you can share so we can see what you are looking to do?
JulieGrindborg
Hi, I meant inside the main/media panel. To be able to not just have one large image there, but to show several images at the same time side by side in different layouts, which may adjust automatically depending on the number of images, like shown below.
OwenGeo
