Classic Esri Story Maps will be retired from ArcGIS Online in Q1 2026 (currently scheduled for Wednesday, February 25, 2026) and was retired with ArcGIS Enterprise 11.0. For details, review the most recent announcement: Classic Esri Story Maps Roadmap for Retirement
The article below contains essential information to help you and your organization manage the retirement of classic Esri Story Maps and successfully transition to ArcGIS StoryMaps.
UPDATE (2/25/26): Classic Esri Story Maps templates are now retired from ArcGIS Online.
What should my organization do?
To prepare for the retirement of classic Esri Story Maps, your organization can follow this three-step process:
- Identify and evaluate: Identify all classic stories in your organization and place them in two categories: 1) those that are still valuable, and 2) those that are no longer valuable. Organizations will have different criteria for establishing the value of each classic story, but it’s likely that it will involve a combination of current usage and overall impact.
- Plan and prioritize: Plan what should be done for each classic story. Review the most valuable stories and prioritize which ones should be remade using ArcGIS StoryMaps or another Esri app builder. For stories that you remake using ArcGIS StoryMaps or another ArcGIS app, you can configure a replacement item to redirect the classic item to. You also may want to, or be required to, create an archived copy of classic stories whether or not they will be remade. For more information about replacement items, archiving, or remaking a classic story, see below.
- Implement your plan: Recreate and/or archive classic stories as outlined in your plan.
How can I help?
Identify members of your organization that can contribute and collaborate on efforts to identify, evaluate, prioritize, archive, and remake classic Esri Story Maps stories.
Administrators have visibility into the entire organization and play an important role in preparing for retirement. Administrators can help identify classic stories within the organization with a significant number of recent views by generating an item view report. Administrators can establish archiving standards and other guidance to shape the transition process.
Authors can provide context about the value of their stories to inform the public or help colleagues make decisions. This will help your organization determine which stories should be prioritized to be remade. Authors should also become familiar with the capabilities of ArcGIS StoryMaps and other current ArcGIS apps so you can help remake classic stories using modern capabilities and make them even more engaging with the latest design elements and storytelling features.
How can I create an archive of a classic story?
There are several ways to preserve a classic story by making an archival version of it. The method you choose will depend on the length, level of interactivity, and significance of the story as well as your organizational requirements.
Some ways to create an archival version of a classic story are to:
- Capture annotated screenshots
- Create a narrated video walk-through
- Use the printing capability, if available, to generate a hard copy or PDF
- Download the story content with ArcGIS Assistant or the ArcGIS API for Python
UPDATE (2/25/26): To create an archive using a method that requires viewing the story (items 1-3 above), you will need to self-host the application code to view a classic story. See "Can I view classic Esri Story Maps after retirement," below. This is not required to download the story content (item 4, above).
How do I recreate a classic story?
If you have identified a classic story that continues to be useful to your organization or the public, you can recreate it using ArcGIS StoryMaps or another current ArcGIS app builder.
To learn about the features and capabilities of ArcGIS StoryMaps, review these resources:
For guidance on recreating classic stories using ArcGIS StoryMaps or other app builders, view these articles:
How do I redirect a classic story to a replacement item?
The October 2025 ArcGIS Online release added the ability to set a replacement item for any app that has been retired. This will allow you to specify the new ArcGIS item you would like viewers to be redirected to in the future.
The redirect behavior will take effect when classic Esri Story Maps are retired in the February 2026 ArcGIS Online release (currently scheduled for February 25, 2026). However, you can already configure replacement items now, but you will only be able to preview and test the replacement configuration from the item details page. No automatic redirect will occur until the apps are retired in February 2026.
This two-phase approach gives you time to plan, configure, and verify replacement items before the redirects go live.
For more information, see Set a replacement item—ArcGIS Online Help | Documentation.
UPDATE (2/25/26): Retired items are now being redirected to their replacement items. If a retired item does not have a replacement, visitors will see a pop-up window that indicates the content has been retired along with a link to the retired item's details page.
What else do I need to know?
You may find these additional tips and resources helpful for managing the retirement of classic Esri Story Maps.
How can I tell the difference between a classic Esri Story Map and a modern one created with ArcGIS StoryMaps?
You can look at a story's item type (on its ArcGIS item details page) or its URL to determine the type of story.
Classic stories are stored in ArcGIS as Web Mapping Application items. They have a URL that contains “/apps/” and the name of the classic template that was used to create it. For example,
https://www.arcgis.com/apps/Casacde/index.html?appid=. ..
https://www.arcgis.com/apps/MapJournal/index.html?appid=.. .
https://www.arcgis.com/apps/MapSeries/index.html?appid=.. .
etc...
Modern stories created with ArcGIS StoryMaps are stored as StoryMap items. They have a URL that begins with storymaps.arcgis.com.
https://storymaps.arcgis.com/stories/ ...
How do I find classic stories in ArcGIS?
To find all classic stories in your account or your organization, execute the search below.
type:"Web Mapping Application" AND typekeywords:"Story Map"
To find stories created with a specific classic template, add the template name to the search.
type:"Web Mapping Application" AND typekeywords:"Story Map",”Cascade”
The individual app name keywords are (note lack of spaces): Cascade, MapJournal, MapSeries, MapTour, Shortlist, and SwipeSpyglass.
Will my classic Esri Story Map items be deleted?
No. Classic Esri Story Maps items will not be deleted. Classic stories will stop working because the application code used to view them is being retired, but the content (text, media, map and embed references, etc.) will remain in the items.
You can continue to view classic stories after the retirement date if you self-host a copy of the application code (see next question). After retirement, you will still have the opportunity to convert a classic story to an ArcGIS StoryMap using the classic conversion tool, convert the story info into a feature layer that can be used in ArcGIS StoryMaps, or download the information using a tool like ArcGIS Assistant.
Can I view classic Esri Story Maps after retirement?
Yes, but only if you are already self-hosting the classic app code or you start hosting your own copy of it. You’ll need a web hosting environment, or you can run the apps on your computer by setting up a local web server.
For more information, see How to view your classic Esri Story Maps after retirement.
Where can I get more help?
If you need help archiving or migrating classic stories, you can work with an Esri Business Partner or Esri Professional Services. Please contact your local Esri account manager for details and advice.
