Zonal stats as table using iterate raster doen't work
4319
06-05-2013 11:20 PM
NasreenKhan
I am trying to calculate zonal stats as tables from multiple rasters in the model builder. I need zonal stats for each raster separately. I was using iterate rasters in the model builder to provide multiple raster input files. But it runs only iterate rasters without any error but doesn't run zonal stats as tables tool. Do any of you have any idea why it is not running zonal stats tools. Model attached.
Thanks in advance for your help and suggestion.
Best
Nasreen
danielmonfort
I'm having the same problem, did you find a solution?
thank you
daniel
curtvprice
Nake sure you validate the model (check mark button) so you know it's totally ready to go.
Also make sure the output path is correct. If it's in a folder, add a .dbf extension so it makes a .dbf instead of an INFO table.
You may want to avoid .mdb ("personal GDB") workspaces, as there are limitations that can bite you. File geodatabase is a far better choice.
Model attached.
Clarification, that's a picture of a model, not the model itself, which must be uploaded as a zipped .tbx.
