Zonal Statistics using polygons (no raster file)
1432
04-10-2013 02:13 PM
Hasin_ShahadMunna
Hello,
This is my first post and I am trying to illustrate my question as simply as I can 🙂
Shapefile 1: Contains sub-basin boundaries of a basin (100+ polygons showing the boundary of each subbasin)
Shapefile 2: Contains numerous (2000+) smaller polygons having their areas calculated within the attribute table.
Goal: Calculate the total area of polygons (Shapefile 2) within the boundary of each sub-basin polygon (Shapefile 1).
Any help is much appreciated.
Thanks a lot.
MarkBoucher
Honored Contributor
Use the Intersect Tool with Shapefile 1 and Shapefile 2. You will get a new shapefile that includes shapes only where they intersect and the fields of both in the table. Then find the field that represents Shapefile 1 and use the Dissolve  tool (Data Management Tools.tbx\Generalization\Dissolve) with that field. This will result in polygons that are dissolved to represent the Shapefile 1 areas only where they overlapped Shapefile 2. If these are outside of a geodatabase, you will have to recalculate the Shape_Area field or create an Area field and calculate the area.
You might get the same results using the Analysis Tools.tbx\Extract\Clip tool.
Hasin_ShahadMunna
Worked Perfectly!
Thanks a lot... 😄
