why the pan sharpening is not active in sympology?? how can i use it ?? and way it's not work??
2176
02-22-2023 09:42 PM
BadrGamal
arcgis version 10.8
332534920_1893705044324531_2975953464626178093_n.jpg332534920_1893705044324531_2975953464626178093_n.jpg
BadrGamal
thank you, I know two ways to do it, but I want to use this tool or why it is not activated.
DanPatterson
Fundamentals of pan sharpening—ArcGIS Pro | Documentation
Pan sharpening uses a higher-resolution panchromatic image (or raster band) to fuse with a lower-resolution multiband raster dataset. The result produces a multiband raster dataset with the resolution of the panchromatic raster, where the two rasters fully overlap.
You have the necessary rasters to use?  Your image only shows that it is disabled, which means that one of the conditions necessary to use pan sharpening hasn't been met.
... sort of retired...
BadrGamal
I have a panchromatec band and i have a composite from landsat 8, can you
help me with this problem??
