The command ???topo to raster??? doesn???t respect the ???mask???!
2675
6
05-30-2012 12:29 PM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
How to make the raster produce by the ???topo to raster??? respects the mask set by "settings environment"?
[ATTACH=CONFIG]14773[/ATTACH], [ATTACH=CONFIG]14774[/ATTACH]
Thank you for the help,
Best
Jamal
by Anonymous User
Not applicable
Original User: stevelynch
Jamal
Did you look into using the BOUNDARY parameter of TopoToRaster?
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Topo_to_Raster/009z0000006s000000/
Steve
PatrickTaurman
Occasional Contributor III
Hi Jamal,
According to the Help, it doesn't look like it uses the Mask environment variable.
Topo to Raster (Spatial Analyst)
If you look at the bottom under Environments, you will see that Mask is not listed.
Patrick.
p.s. To better direct questions dealing with Spatial Analyst tools, it is better to post in the Spatial Analyst forum, not the ArcGIS Desktop - General forum.  Same goes for raster data, it is better to post in the Imagery and Raster forum and not the ArcGIS Desktop - General forum.
by Anonymous User
Not applicable
Jamal
Steve
JamalNUMAN
Legendary Contributor
Hi Jamal,
Patrick.
Many thanks for the answer Patrick.
Please, have a look on the screenshot below and let me know what do you think?
[ATTACH=CONFIG]14820[/ATTACH]
Jamal Numan
by Anonymous User
Not applicable
Jamal
Steve
Perfect. Your replay has solved my question. Many thanks Steve.
I think this is similar to the �??create TIN�?� tool.
But still the command �??create thiessen Polygons�?� doesn�??t respect any kind of mask!
[ATTACH=CONFIG]14821[/ATTACH], [ATTACH=CONFIG]14822[/ATTACH], [ATTACH=CONFIG]14823[/ATTACH]
[ATTACH=CONFIG]14825[/ATTACH]
Best
Jamal
by Anonymous User
Not applicable
Jamal
Because the environment shows up does not mean that it is supported. Random numbers in the environment, for example, are not supported when you do CopyFeatures.
The tool's help lists which environments are supported.
Also, MASK is supported by nearly all the tools in the Spatial Analyst toolbox, all the Geostatistical Anlyst tools that output raster (but only from 10.1 onwards). The tools in the Conversion toolbox and the Raster tools in the DataManagement toolbox, for example,  also do not support mask.
I hope this helps you better understand which tools support mask.
Steve
JamalNUMAN
Jamal
Steve
Many thanks for the elaboration Steve. Very useful.
Best
Jamal
Jamal Numan
