Spatial Join with Rasters?
10599
10-22-2014 08:07 AM
LiaLaporta1
Hi
I am new to ArcGIS so please forgive my ignorance.
I believe my problem is quite simple. I have a land cover raster (Corine, 100m pixel), and I have created a Species Richness raster (number of vascular plant species) , w/ same pixel and extent as the land cover raster, based on local data. Now I would like to investigate on the relationship between land cover and number of species. My questions:
a) is there a way to make some sort of spatial join, so that I would know the land cover type AND species richness for EACH pixel?
So I would have a table like:
ROWID | VALUE(LandCover) | VALUE (SppRichness)
b) or must I convert all this to vector in order to make such a join?
c) or, better yet, is there another way to get the comparison I'm looking for between the rasters? My idea is to try and find some sort of correlation - ideally, an average number of species richness per land cover type (a good estimate, with standard deviation).
Thanks in advance
Lia
DanPatterson_Retired
Check the Combine Tool in the Spatial Analyst extension assuming you have it and your data meets the conditions
