Re-opening Suitability Model
7906
13
03-23-2022 11:40 AM
PaulBooks_CoA
When I re-open an existing suitability model from the content pane, the parameters no longer appear under the suitability pane and I am unable to make an further changes to transformations and weights. I still see all the transformed rasters under sources but they are not in the suitability pane or the group layer. Any recommendations on how to resolve this issue would be greatly appreciated.
SteveLynch
What version of ArcGIS Pro are you using?
Please include a screenshot of what you are seeing.
...and, if you've not opened the Suitability model after opening the ArcGIS Pro project, see the image below on how to open it.
PaulBooks_CoA
Hi Steve,
Thanks for your reply. That is the same process I used to re-open the model. Below is a screenshot showing the source rasters and the suitability pane having no visible parameters.
MaritFrost1
Hi! I have this same problem and it is killing me. Suitability modeler loses all of its iterative workflow for me if I have to re-transform everything each time I close the model (or ArcGIS crashes). Have you found any way to reopen the transformation pane without everything resetting and re-transforming every criteria?
SteveLynch
SteveLynch
Do any of your criteria rasters appear in the Suitability group layer in the Contents pane?
Did you convert the criteria rasters to Web Imagery layers or another raster dataset on disk?
Can you email me ([email protected]) the .sam file, it is a JSON text file in the same folder as your ArcGIS Pro project?
GloriaBlaise
Hi Everyone,
I am having this exact issue and have no clue whether I should just stop using the suitability modeler and use a classic method to weigh these layers. All of the transformations are removed from the parameters and I cannot locate regions unless I do the transformations all over again. The suitability map is still in the project but somehow no longer linked...
Error message
SteveLynch
I'm sorry to hear that you are having problems.
Once you've done the transformations you need to create a full resolution Suitability map before doing Locate Regions. If you look at the properties of the suitability raster you'll notice that it is an .afr (a function raster) and it needs to be persisted to a full resolution resolution raster. This is all done within Suitability Modeler.
GloriaBlaise
Thank you Steve,
I am using 3.0. I did not run this before it crashed and so I will give it a try again tonight and see if I can get past the final run before locating.
EmmaCurran18
@SteveLynch I would like to note that I am having the same issue with the Suitability Modeler not keeping transformations intact after the model pane is closed.
