raster calculator expression help for linear mapping
5536
05-07-2015 03:14 PM
by Anonymous User
Not applicable
So i have two raster (raster A and B) that represent maximum and minimum value of a parameter. I have another raster that reprensent the value that i want to use to calculate the values between the min-max range using this equation:
(?function?)*(-exp(rasterC))
The problem is that the result sometimes is not between the range in some cells. What kind of statistical function can I use for ?function? to remain between min-max range?
I used (Max-min/mean) for ?function?... but is not the correct function.
curtvprice
raster_a = min raster
raster_b = max raster
raster_c = 0 -> 1 raster
A linear mapping of C (0->1) on to the linear range of (B->A) is
"raster_a" + ((1.0 - "raster_c") * ("raster_b" - "raster_a"))
SepheFox
If I understand your question correctly, you need the Con tool: Con (raster C, raster A, raster B, "value = 1")
JayantaPoddar
In Raster Calculator, write a conditional statement like below:
Con(InRasC = 0, InRasA, Con(InRasC = 1, InRasB, InRasC))
Think Location
curtvprice
SepheFox
Oh, I see now what he's looking for.
