Polyline to Raster "No Data"
3489
10
12-26-2013 04:02 PM
aaronboci1
I created a raster from contour lines. The contour has a 2 M resolution and I set the cell size to 5. Increasing the cell size is not an option and I may even run it again on a smaller scale. I have a lot of cells that did not have a contour line pass through them so they came up as no data. What tool should I use to give these cells an elevation that is either equal to the closest polyline or even better, a distance weighted value between two cells that have a value. I like the ideas of interpolation with IDW, nat neighbor, and kriging, but they work for point values. Is there a better way than transforming my cells to points, then interpolating, and then changing them back with values?
SteveLynch
How many rows/columns in the raster you created using PolylineToRaster?
and
2m contours mean that vertically the DEM is sliced every 2m.
What I'm trying to determine is:
a) what is the cell size of the DEM you want to create?
b) how did you decide on this cell size?
c) given the extent and cell size, what size raster will be created
If you want to take this offline please email me at [email protected] and we can post the conclusion to this forum post.
Regards
Steve
