Point Statistics output - force 32 bit pixel depth?
1929
08-03-2011 11:57 PM
UrbisMelbourne
My input: point data, with the input field being population counts
Output raster is going into a geodatabase, so it should be a GRID by default.
I'm using a circle neighborhood, with a radius of 5000m, and the statistics type is SUM.
The output raster tops out at 65535.  This seems to indicate it's a 16 bit raster.  I know for a fact that the population sums within a 5km radius in some areas should be in the low 100,000s, so I don't understand why the GRID file isn't defaulting to 32 bit unsigned in terms of pixel depth.
What am I doing wrong here?  Can I force the output to be 32 bit unsigned?
UrbisMelbourne
Couldn't fix this issue, so I eventually gave up and implemented a workaround: in my point features, I added a new FLOAT field and calculated across the values, divided by 10.  I then re-ran the Point Statistics on the new field, and used Raster Calculator to multiply the resulting raster by 10.
Tedious to have to do this for what should be a one-step process, but there you go.
MatthewArmistead
Nathaniel I'm running into the same problem and cannot find a solution other than the workaround that you mentioned.
http://support.esri.com/en/knowledgebase/techarticles/detail/35053
I did find this Knowledge Base article that recommended changing a field in the Raster Dataset options under Customize > ArcMap Options but that did not change anything for me. No matter what the number is set to it still tops out at 65535.
kevinjohns
same thing is happening to me. i'm running pointstatistics on a statewide census points layer (50mm features) on a double field and depending on the field, it creates an unsigned 8-bit or a signed 16-bit raster. i'll try converting the double field to a float field and see if that helps, but it'd be really nice if this could be addressed without significant workaround.
