Hi, I am new to the solar radiation toolbox and fairly new to GIS. I am trying to run the point solar radiation tool, but keep receiving 2 errors: 010327: Unable to set analysis window and 010067: Error in executing grid expression. I have my points and DEM raster mapped/projected in the same coordinate space and my points are within the raster. I tried multiple days with a lower (default) sky size and a single day with a higher sky size (2800) and still get the same errors. Any advice help would be incredibly helpful. Thanks!
That is an odd error message. Can you verify your environment workspace or scratchWorkspace is set to a valid file directory or geodatabase
Are you able verify if this tool works with any other data? What about area solar radiation with the input DEM?
what version you are using?
How large is the area you are trying to calculate? If it is a large area can you test a smaller one? For example clip out an area or you can an environment extent to a smaller (test) area? IE: Zoom in to an area where you have points and set the environment extent = "same as display".
Are you able to .zip and share your data ?
Thank you. The inputs you sent ran with recent version of ArcGIS Pro 2.9.2 without issue.
However, I noticed you are using input table (x,y) for the locations. I don't have a 10.7.1 readily available to but can try with the latest ArcGIS 10.8.2 current release of ArcMap to verify.
Perhaps you can convert the table to an input feature class instead. You should be able to create features using the make-xy-event-layer tool using the spatial reference of your input DEM.
Note:
The output point feature layer created by this tool is temporary and will not persist after the session ends. You can export this event layer to a feature class on disk using the Copy Features, Feature to Point, or Feature Class to Feature Class tool.
let me know if the feature input work for you...
Yes, I previously ran the area solar radiation with the same DEM.
I fixed my file directory and it worked. THANK YOU SO MUCH!
Hi snoward,
I tried to run the Area Solar Radiation tool and got the same errors:
ERROR 010327: Unable to set analysis window.
ERROR 010067: Error in executing grid expression.
Failed to execute (AreaSolarRadiation).
Could you please let me know how you solve the issue exactly?
Hi! I am having this same issue? Were you able to solve this? Thanks!
Hi Rachael. This was an old issue but looked to be solved by making sure the output workspace or scratchWorkspace is set to a valid file directory or geodatabase. Make sure you have write permissions. Are you able to run with additional tools or input data?
What version of ArcGIS are you using? If using ArcGIS Pro 3.2 or greater I'd recommend using the Feature Solar Radiation tool or Raster Solar Radiation tool which provides enhanced functionality and performance.
