Iterate Raster in Model Builder with Raster Calculator
5264
07-22-2013 07:19 AM
DavidCampbell
New Contributor III
Hi All,
I have a function I want to apply to a raster. I have multiple rasters, each will need this function applied. Here is the function:
( 11.16 * Sin( FocalStatistics( "%Name%", NbrRectangle( 3, 3, ???CELL??? ), "MEAN", "" ) ) / ( 0.765 + 2.625 *  FocalStatistics( "%Name%", NbrRectangle( 3, 3, ???CELL??? ), "MEAN", "" ) ) ) / ( 11.16 * Sin( FocalStatistics( "%Name%", NbrRectangle( 3, 3, ???CELL??? ), "MEAN", "" ) ) / ( 0.765 + 2.625 *  FocalStatistics( "%Name%", NbrRectangle( 3, 3, ???CELL??? ), "MEAN", "" ) ) + 1 )
As you can tell I have instigated 'iterate rasters' to get the %Name% input. I have this function currently stored in raster calculator within model builder. When I try and run the tool it crashes out saying that the raster does not exist.....it exists so obviously I am referencing it wrong inside of raster calculator but i don't see where I am going wrong. I am running 10.1.
Any help would be appriceated.
DavidCampbell
New Contributor III
I have it solved....... put the output from iterate rasters to the collect values model tool. Use the output of that as the input in the raster calculator. So pull %name% not from the iterate rasters but from collect values.
PompierOlivier
Hello Careys,
Thanks for the "collect values" solution but i have an issue with it. Model builder doesn't allow me to pipe "Output value" of Collect values tool in Raster calculator. How did you make it work ?
Many thanks
Olivier
curtvprice
MVP Esteemed Contributor
Hi All,
( 11.16 * Sin( FocalStatistics( "%Name%", NbrRectangle( 3, 3, �??CELL�?� ), "MEAN", "" ) ) /
  ( 0.765 + 2.625 *  FocalStatistics( "%Name%", NbrRectangle( 3, 3, "CELL" ), "MEAN", "" ) ) ) /
  ( 0.765 + 2.625 *  FocalStatistics( "%Name%", NbrRectangle( 3, 3, �??CELL�?� ), "MEAN", "" ) ) + 1 )
I unchecked your answer suggesting the use of Collect Values because it is incorrect. The correct answer is to use the Output Raster output of Iterate Rasters (not Name).
DavidAinley1
I'mn have a similar issue... by output raster do you mean the output of the iterator or is that a tool on its own?  I need to be able to select individual bands after many rasters have pulled into the model.
curtvprice
I mean the output of Iterate Raster.
Rather than pull multiple rasters into a model, it is usually much easier to go with the flow and process each raster in the iteration one at a time. You can select individual bands using the Select Data tool on each iteration.
I suggest starting a new, more specific thread if you want help with your workflow that involves extracting bands. Sounds complicated.
UPDATE: Never mind, I see you did: model builder to create NDVI
