is there a way to label the cells of the raster with theirs values?
3905
04-12-2011 10:18 AM
JamalNUMAN
Legendary Contributor
please, see the attached image that shows the question
Thank you
regards
Jamal
Jamal Numan
TimothyHales
Esri Notable Contributor
No, you cannot label a raster.  The closest thing you could do would be to convert the raster to points and then label the points with the symbology null.
curtvprice
Jamal, the best you can do is to create a point feature at the point you are interest in, populate it with the raster value using the Extract Values to Points tool, and then label the point.
Hope that helps.
TimothyHales
Check out this older post: How do I 'label' an elevation raster to see individual cell values
It references the Cell Tool: http://edndoc.esri.com/arcobjects/9.0/Samples/SpatialAnalyst/CellTool/CELLTOOL.htm
You will notice that the tool was written at 9.0.  You can add it into ArcGIS 10, but only the boundary tool will work.  There is a extent error with the other tools.
SteveLynch
